Hello everyone!
I just bought a '79 B, site unseen, and drove it home from San Francisco to Idaho! Paint and body look great! 80k miles, runs good. Interior excellent. The car sat in a garage for most of the last two years, driven less than 400 miles in that time.
Yeah for the car, bad timing for me--record rainfall in SF and snow on every mountain pass!!
The car ran pretty well, with a couple of exceptions:
1) Failed to start one night (in SF) while parked at a store. Played with the wires to the fuel pump and she started and ran fine from then on. (The flow at the fuel filter still looks a little low to me...should it be full?)
2) On the way home, some accessory electrical circuits died. Found a couple loose fuse connections in the fuse block and got these back up with minor effort. Remember too, everything was VERY wet.
3) The exhause came apart just after the catalytic converter, lost all the nuts...lucky for me I brought bailing wire!
4) The windshield leaked like a sieve!! Actually, it appeared to be coming in under the windscreen bracket. Did I mention that is was VERY wet?!?
5) Noticed a nice pool of oil under the car after she parked in my garage for a couple of days.
6) Overall, the engine seems to run fine, but there isn't a ton of power and I experienced some uneasiness while cruising at constant speed. She idles smooth, albeit a tad fast and accelerates smoothly, just coughs a bit when your foot is barely on the throttle.
7) Brakes are a mess! At low speed, one front locks up easily. At higher speed, she pulls to the right when you hit 'em. And, if you haven't touched them in an hour or more, the first pump goes pretty much to the floor!
Call me crazy, but I still love this car!
Obviously I have many things to look into. This is where I'm seeking your advice and experiences! Please lend me your suggestions and think of it as, this is what I would do first, then, etc. Foremost, I want this to be a solid running car. And, if I can improve the performance some along the way, that would be great!
I'm planning on starting with the brakes so she is, at least, safer to drive. Could this be bad pads and tons of air in the lines or do you think I have a more serious problem? I'll be digging into this on Saturday...
Thanks, in advance, for all your input!!
P.S. 1979 MGB, 4 speed, w/ cat, single Zenith carb
