Well I decided that today is the day to start resurrecting my TC2500. The very first thing I did was to put some coolant in the radiator (the previous owner had drained the system years ago). There's a slow but steady drip coming from a metal water pipe. It's the pipe that goes backwards from the bottom of the water pump and runs between the exhaust manifold and the engine block. I can tell from using a little mirror that the leak is coming from a tiny split in the pipe's seam, about an inch back from the water pump connector. Is there an easy way to repair this leak, or will I have to find a new pipe? Thanks!
