I want to repair a leaking steering box on my BJ8. I have the two key parts of oil seal and dust excluder. The shop manual says that I need a service tool (extractor) to remove the steering arm from the splines on the shaft. I do not have this tool labeled as 18G 75A. Is there an alternative procedure that I could use to remove the steering arm without damaging the shaft? The oil seal replacement seems simple after removal of the steering arm. Any suggestion would be appreciated.
Jack White
Leesburg, Virginia
Jack White
Leesburg, Virginia
