Don Elliott
I have removed my valance and radiator. Now I want to remove the silent-bloc bushes in the cross-rod that links the Pitman arm on the bottom of the steering box to the idler arm. Is there a special tool like a ball-joint splitter fork that will break the conical joint on the bottom of the Silent-blocs ? Any other suggestions. When I did my restoration from 1987 to 1990, the rubber in both the bushes was so worn, they literally fell apart when I dis-assembled them. This time it's harder to do.
