Removing the Ugly Rubber Bumpers
BASS
Are there any special tricks in removing the rubber bumpers? Anyone have any pics of their 1500's without them? Also, will there be holes everywhere if I take them off?? I know I will have to do something about the turn signals up front if I remove the bumper (i.e. drill the turn signal assemblies into the fenders, correct?)..
RickB
heheheh...
Yes..., why yes..., I believe I do...
You can get started here:
(sorry I don't have these in a format of any kind)
<span style="font-weight: bold">https://www.bastedo.net/midget/
</span>
JPSmit
and yes I do too -
https://tinyurl.com/3b3vo7.
You can see that the old bumper brackets have been cut off and capped and the lower air holes covered as well. My guy made very funky brackets to mount the new bumpers which I don't have pics of right now but will get.
https://tinyurl.com/2kqcpq
https://tinyurl.com/2m453b
Ms Triss had the dubious advantage of having been lightly rear ended before I got her, thus, unlike Rick it was easier for me simply to get a new rear valance to recreate the "humps" under the taillights. He did have to make a bracket for the bumper.
Rick put his signal lights in the existing fender holes. I had mine filled in and will be having him put in bugeye signals instead - a look I like better.
Having done all that, get pre-rubber bumper front springs (lower) and de-arch the rear springs an inch to get the proper ride height.
Bottom line is it's easy, not too costly and looks a hundred times better - go for it
PS - Not sure what the NJ laws are but if I were still in Florida where the car dosn't need to be certified in the same way I might have left the bumpers off all together.
aeronca65t
tosoutherncars
We had a thread on this a little while ago...
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/427856/Re_rear_panel_replacement
Looks like the Moss rear panel, and the two rear corner 'patch' panels would convert the rear.
In the front, pre-75 (74) fenders are a bolt-on. But they are expensive new ($700+ each?) and usually rusty if buying used... make sure you get pictures from *inside*. Expect to pay about $300 for a pair in usable condition.
And yes, as JP mentioned... the RBs had taller springs, to meet US DMV requirements, and compensate for the extra weight. Earlier springs, and/or front spacers for the spring pan, to lower the car, will restore ride height.
aeronca65t
And there's also spacers on the front mount for the rear leaf springs on RB cars. They are plates that are about 5/8" thick. If you remove them and add 1" spacers *between* the axle and the leaf spring, you will end up with a more reasonable ride height in the rear.
RickB
I feel like the job I did has a couple of great advantages for the car I wanted to end up driving.
1. Very inexpensive.
The most expensive part I bought was when I splurged and bought the new grill surround from those Bright guys in England.
2. Very easy.
Unbolting and removing old stuff & bolting new stuff on.
Painting was achieved with a can of brown Rustoleum.
Mine is a driver, not a trailer queen. :wink:
Originality isn't very important on this car (I bought it with the Nissan drive train already installed). On this car my enjoyability is the most important thing.
I just want the car to look a certain way, so that's what I have aimed for.
I hope to replace the hood, trunk and front fenders eventually using mid 60s donors. Hood & trunk because they are both damaged, fenders just bcause they have the "right" location for the turn signals.
tr6web TR6 Need advice removing downpipe nuts Triumph 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
