I am at a loss and hoping for some help here. As you can see I have a round steel plate that holds an oil seal and bearing in place. It has four countersunk screws. When the screws were installed in 1963 they were "punched" so they would not turn out.
At this point I have managed to get three of them out.... isn't that they way it always is?
I just cannot get the fourth screw to budge.
I've taken a dremmel tool and relieved the punched area.
I've heated the area around the screw.
I've let it sit for days with penetrating oil
All of the above has not worked.
The screw head is really misshaped from the screw driver twisting out. Using an easy-out does not seem like a good option since the likelihood of drilling a hole dead center for the easy-out seems slim.
The only option I can see is to try and grind the head off and then may get a vise grip on the thread and twist it out if I'm lucky.
ANY OTHER IDEAS that you guys have?
