You're talking about a TR4 gearbox? If so, you just undo the 4 bolts that hold the front cover to the main casting and slip the cover off with the seal inside. Then you pry the seal out of the front cover, replace the seal and reinstall the cover. Probably best to cover the splines with something as you install the cover (so the corners of the splines can't nick the seal lips) but no special tool is required.
Be sure to get all of the old seal out, though. Sometimes they break and leave part of themselves behind, which will make it impossible to properly install the new one.
Wrong:
Right:
