nevets
I need to replace my overdrive solenoid (no clicking sound when flipping OD toggle on with ignition swithed on in 4th gear), I assume that it will be necessary to remove the transmission tunnel, but first I need to remove the beautifully fitted carpet. Questions: How is the ashtray removed? What about the handbrake lever mount? the shift lever boot? Any suggestions / tips would be appreciated. Thanks
Hi Guest!
