Hi Everyone,
I've been sandblasting my BJ7 frame & inner body the last few weekends using standard blasting sand. It goes slow because my compressor will only sustain 90 lbs @ 7CFM, so I strip a little at 50 lbs and wait for the pressure to come back up when it drops below 25. Anyway, as I work on the interior spaces in the cockpit and the trunk, the remnants of the adhesive will not come away with the sand. Should I use a different media for this, or should I try to remove it with solvent or a wire wheel instead?
Any experience in this area? Thanks in advance!
Lance
Lance
