Removing Break Fluid from Bn6
BN6_2197
As posted in another thread I have to replace one of my wheel cylinders of the front brake of my BN6. For this I want to remove the break fluid from the break system. Can anybody advise me on the correct procedure? I only found the way of correct bleeding in the workshop manual.
Volker
steveg
Volker,
You can use one of these to pinch the flex hose so the fluid doesn't leak out when you're doing the repair. You can also seal the vent in the reservoir cap with tape. That way you don't have to remove the fluid.
Update: a kitchen basting bulb-syringe is an inexpensive way to remove the fluid from the reservoirs.
blueskies
I agree with Steve. Unless you want to also change out all the brake fluid, you should not lose that much when replacing a wheel cylinder. It does not take long to bleed the air out of the system. Even though it might not be necessary, I might bleed the brakes at all four wheels after working on the system in order to get any air out.
TimK
Fluid should be changed. Start by suctioning out the fluid from the reservoir. Then open each bleed valve starting with the right rear wheel and have a helper pump the brakes to push out the fluid. Then do the left rear, right front, left front. Do your brake fix, then refill the reservoir with new fluid and bleed the system starting with the right rear, then left rear, right front, left front. Make sure to refill the reservoir after each wheel to make sure you don't allow air to re-enter the system.
HealeyRick
Tim,
I don't think your brake bleed sequence is correct for a LHD BN-6. The brake bleed sequence is usually described as bleeding from the farthest wheel away from the master cylinder to the closest wheel to the master cylinder which is the sequence you've described. It more accurately should be described as the wheel with the longest pipe run from the master cylinder to the one with the shortest. If you look at the diagram of the pipe runs of the 100-6:
You'll see the longest pipe run goes to the left rear, then the right rear, then the left front, then the right front. I spent years doing it the way you described until Rich Chrysler pointed out the correct way.
TimK
Thanks for the correction, I assumed a BN6 was the same as BN7. While trying to be helpful, sometimes I exceed my actual level of knowledge. It's good there are so many experts on the lookout.
steveg
Looking at the Moss diagrams, it looks like the left rear is the longest run on all models. Would guess the RHD models would be the same except for a shorter run from the MC to the 5-way union.
BN6_2197
BN6_2197
Gents, I want to replace the brake fluid in the context of repairing my cylinder since the fluid is more than 5 years old. I have heard that the fluid should be changed on regular basis to to water that might mix with the fluid. By this reducing the power of the brakes.
Concerning the fluid push out sequence: is this the same as the bleed sequence Rick mentioned. So far I understood that the blee sequence is typically the sequence to refill the fluid into the system.
Concerning the tools:
* What tool do you use typically to suction the fluid from the reservoir? Can I use a bigger medical injection for this?
* Tim mentioned a "helper pump" to push the fluid out of the blee valeves: is there any available in a shop or did you handcraft it yourself?
Unfortunately the tiny URL of Bob's post does not work.
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
