Removing Air Filters
Jersey
Is there any easy way to remove the two air filters on my Mark II? I see the nuts to release them, but it looks like I have to remove the entire carburetor to get to them.
Help?
Thanks.
I have a Mark III but the should be the same. There should be two nuts per filter. They can be removed with the carbs on. I use stubby ratchet wrenches(about 3 inches long). The hard part is putting them back with the lock washer. I have ground off a little of the stud to allow better finger access. I hope this compatable with your system. BJ8's are a tighter fit than your Mark II.
TH
healeynut
Jersey -
Just use an open ended stubby wrench. Once loose they'll come right off with your fingers. No need to remove the carbs.
terp83
Jersey-
Somewhere in the past 30+ years as a Healey enthusiast, I read that it was a good idea to obtain an inexpensive combination open-end wrench 1/2" on one end and 9/16" on the other, and cut it in half, resulting in two stubby-shafted open-end wrenches. It seems as though the recommendation was related to removal and replacement of the SU air filters. Over the years, each of these resulting wrenches has come in handy for other projects as well.
Jerry
MarkA
Jersey,
I took a combo wrench of the correct size (1/2"?) and ground down the box end so that it was very thin. It doesn't take much torque to loosen. Once you get two - three partial turns on the nuts, the rest is easily done with your fingers.
The real trick comes in getting the nuts started back on the stud. When you do drop one of the nuts down in the frame, you will probably find others floating around down in there from previous owners (I found three).
Enjoy,
Mark
AUSMHLY
FWIW, to aid in not dropping the nut when trying to put in back on, I use a magnet pen. (disclaimer for correct name for this tool.) The magnet holds both the lock washer and nut together for the line up to the bolt.
Regardless what you do there is an opening in the frame below the carbs that eats tools and parts. Stuff a rag in there before you do anything. Roger's magnet may also help you to retrieve things down that hole. I have one and use a bit of tube around the magnet so it will slide down into the frame easier(which other wise grabs the magnet). I like his way of holding the parts. I will try it this weekend since I'm pulling the head to replace the head gasket and the carbs need to come off. Thanks, Roger.
GregW
Platinum
I remember reading somewhere about drilling out maybe the stud holes and using bolts instead of the stud/nut setup. Since I don't have SUs, I didn't pay too much attention to the tech tip. I thought it was on Jim Werner's site. I hope he moved his valuable site 'cause the address I have says the server is shutting down.
Wor Bobby
My solution in the end was to drill all the way through the filter from back to front and insert a section of aluminium tube to use as a sleeve of sufficient diameter to allow the bolt to pass through. Longer bolts then obtained and fitted through the front of the filter into the carb body.....boy does that save some aggravation;)
Rivet nuts would work great with bolts, but you'd have to drill out the holes. I have K&N filters that use bolts, and if I ever take the carbs off again I'll consider it (I just bought a rivet nut kit for a similar problem on a tractor), But, the filters have tiny acorn nuts to hold the outer plates, and they're a PITA as well.
Rob Glasgow
I like the idea of installing a long bolt from the face of the filter all the way through to the manifold. What do you think about tapping the intake manifold hole to accept the bolt? That way, you’re not dealing with a nut on the back side. Not sure how large the bolt diameter would need to be. Any guesses?
Rob Glasgow
I took a look at my car today and realize I was mistaken when I said you could thread the manifold to accept the new long bolts holding the air cleaner. Duh. The air cleaners mount on the carburetors but the concept is the same. Just thread the holes where the current bolts go and you have an easier method of mounting the cleaners.
Of course you would need to remove the carbs in order to thread the holes and that in itself is a pain.
Does this make sense to anyone?
I'd be a little uncomfortable threading these holes; the carb bodies are aluminium and you do need to torque the nuts/bolts a bit since there should be a paper gasket under them. I would, however, be quite comfortable using a Helicoil--or similar--or a Timesert (assuming you can set the insert flush). This wouldn't work for the original Cooper grasshopper catchers, since they have studs, but with any filter with a removable cover for cleaning would work. With the HD8s on a BJ8 it's still a PITA to get to the front filter though. At least we don't have to deal with oil-bath filters.
Patrick67BJ8
I haven’t done this, but, why couldn’t a hole be drilled in the air cleaner stud and a spring with a washer being compressed and then insert a cotter key through the air cleaner stud? Since the air cleaner is cleaning the air going to the intake manifold the suction would also help seal the surface of both pieces.
pakiwi Removing Air Pump Spridgets 1
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
