trfourtune
just a reminder. for those that park our cars for the winter, change/ bleed the brake and clutch fluid before (BEFORE!!) you park it. when spring time comes CHANGE IT AGAIN!!!
then you will avoid internal corrosion that happens from moisture absorbtion. cheap. you wont get that pedal suddenly go to the floor syndrome.
rob
rob
