Remember when carb cleaner was so strong ....
krswen
it made your eyes water, but it actually WORKED? What is the best cleaner available these days (in a bucket with a basket included)?
Ken
Hot Wings
The good stuff was Methylene Chloride AKA DCM or Dichloromethane. It's still a component of many paint strippers. If you can't find the good carb cleaner you can make your own by extracting the DCM from paint stripper with water. It's a very simple process. The DCM is not water miscible and will be the bottom fraction. Drain this off into a metal container and cover with some more clean water to keep it from evaporating.
OSHA and the EPA don't like this chemical so find the MSDS, read it, and make sure you understand it before use.
Edit: The last bucket (Gunk brand) I bought was from NAPA many years ago. They charged extra for a bucket with the basket. Don't do too much carb work anymore so it's still setting under the bench.
TR3driver
Great Pumpkin - R.I.P
I've heard that the latest "Hydroseal II" still works well, but haven't tried it myself. Their original formula was great stuff, but apparently outlawed in the US now.
https://www.gunk.com/products/DET_HS3K.ASP
One thing I learned the hard way, though, don't ever stick a hand into it without a glove. Even if you wash immediately, it crawls under your fingernails and hurts for weeks.
JPSmit
The spray still takes the varnish off an antique kitchen table. Don't ask me how I know.
Hot Wings
Just certain states. Gunk Hydroseal II is non chlorinated but they still offer a chlorinated spray product.
Typical old carb cleaner formula:
Methylene Chloride (Dichloromethane) 75-09-2 55-65
Cresols Mixture 10-15 ( i suspect it's the m-cresol that was the active isomer with the p-cresol giving the distinctive odor)
Mixed Xylenes 1330-20-7 20-30
Sodium Bichromate 10588-01-9
Ethyl Benzene 100-41-4
The new formula can be found in MSDS sheets.
Wynns and Johnsens also sell chlorinated carb cleaner in a spray can - some states. Kind of ironic that DCM is still available in a spray but not in a can that seals in the VOC's.
PAUL161
To clean a carburetor today without the old products out there anymore, I use industrial grade Purple Power/Citrus cleaner. It's over twice as powerful as the stuff in the auto supply stores. I take the carburetor completely down, place the parts in a basket, (Do Not Get This Stuff On Your Skin) it will suck the oils right out of your skin, then let the parts soak over night completely covered. Rinse everything with water, dry it and go from there. Works for me. PJ
Deleted member 8987
Yeah...I used to do a LOT of carb work. Had the metal bucket with basket in the corner. One day, walked into the shop to a BAD odor and wet floor. The stuff ate through the metal bucket.
Dave
Shane
:lol: As someone that still lays his parts out on our kitchen table, it's only a matter of time before I find a solvent that does the exact same thing.
JPSmit
Oooo solvent Russian Roulette - I like
G
the new stuff works fine for me. My bucket is about 4 years old I think. It's brown, not the crazy yellow stuff.
JP, seriously? You must not like being married....
JPSmit
Basil Anyone remember Dave Russell? Austin Healey 5
3798j A Holiday to Remember - Chevrolet Other Cars 3
D Off Topic Remember to drive your Triumph Triumph 3
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
Jim_Gruber Remember "The Mite" a beautiful "almost a BE" Build. It's back on BAT and Badder than ever! Spridgets 6
Rob Glasgow Do you remember these?? Austin Healey 9
JPSmit Help me remember - wiper question Spridgets 6
kennypinkerton MGB Things I remember that I did to my MGB... MG 4
B 1988 Healey Conclave in Shangrila Anyone remember?? Austin Healey 11
Keoke Here is how to remember how to reassemble your engine Austin Healey 4
PAUL161 T-Series Remember This? MG 6
PAUL161 Do You Remember Cheap Gas? Other Cars 39
Basil General MG For those who remember Tony Barnhill MG 25
Morris Oh now I remember... Spridgets 1
T for the life of me I can't remember Triumph 5
D Cannot remember ever seeing this before Spotted 6
rikiwho123 does anyone remember this web site? Triumph 3
sqbsprite Do you remember the 30th event? Spridgets 4
S Cant remember where they go !! Spridgets 9
regularman OK, help me remember Spridgets 7
toysrrus "REMEMBER"; "THANK" a VET today for their Service Triumph 4
PATR8 Remember when I said ugg what could happen next? Triumph 5
V Older Triumph Drivers may remember the days Triumph 19
YankeeTR Massachusetts TR's..Remember when these were $500? Triumph 0
pbraun Argh! I can't remember the model # of that Rover.. Other British Cars 0
pbraun Argh! I can't remember the model # of that Rover.. Rover / Land Rover 7
svtmikey Un-joints - I don't remember them being this hard! Triumph 29
jlaird Do you remember Spridgets 17
G Remember the British Invasion of the 1960s? Well.. MG 5
frankenstang57 TR4/4A remember the free tr4? Triumph 5
R firewall- no problem. I'll remember! Spridgets 4
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
