bthompson
Nigel has a case of bachelor lean. Par for the course. The passenger side front wheel has excessive negative camber: I've just discovered the inside edge is far more worn than the outside edge. Also par for the course.
I was pondering just now: many have said that the solution for bachelor lean is to lower the opposite side front suspension. Does this mean the low driver's side rear is pulling up on the passenger's side front? Would this cause the alignment to go wonky on just that one wheel? (The wear on that tire is worse than the other three, like it is scrubbing.)
I did a quick rock-and-jerk check on the front wheels, and judging by feel there's no obvious bearing or bushing wear.
What do y'all think? Would the best course of action be to a) drop the spring pan to correct the lean, b) try new trunnion bushes, c) shim the damper up, d) adjust the toe-in to minimize the scrub, or e) ignore it and just start rotating tires so they all wear out together? Keep in mind I have a bad back and no money, so "just buy a new suspension" ain't gonna fly in this case.
