[ QUOTE ]
The choke bracket mounted on the scuttle [Fire Wall] was always plated Roger. However,it may not be clear which choke cable bracket is being discussed or just Keoke is /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/grin.gif.
[/ QUOTE ]
My question was/is about the two brackets in my photo. Currently, both painted black. One bracket is horizontal screwed to the engine, and the other is vertical, holding the choke cable. Sorry for the confusion, is that clearer?
From my orginal question I find another item on my car which is not correct. Keoke now informs me that the bracket mounted on the fire wall should be plated, where as mine I find was painted black. I will change that. Thank you Keoke.
Maybe I should just take a photo of my engine compartment and let you guys have at it. Wow, she's clean, but here is a long list of items you need to make changes /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/england.gif
Cheers, Roger
[/ QUOTE ]
OH MY GOSH don't do that Roger! cuz I see them non british grade 8 bolts in there and no throttle stop on the manifolds if you do that you won't be able to drive this car for another 19 Months. /ubbthreads/images/graemlins/lol.gif.Seriously,you only showed two of the brackets that are involved, there are three on the manifold. Two of which you have shown and the little one holding the rear carburetor throttle return spring is the third one and is also painted BLACK. The near vertical choke cable support bracket you show must be per personal choice unless you are to go along with concours.Mine are engine green.-Keoke- /ubbthreads/images/graemlins/cowboy.gif
