Martin AH 3000 MK III Phase 1
My BJ8 turns approx. 3.500 revs when driving in 4th gear with overdrive. I want to reduce the revs for long distance drives and see two technical solutions:
1) the standard rear axle for cars with overdrive has a crown wheel and pinion with 11 x 43 teeth (3.909:1 ratio). Cars without overdrive have crown wheels and pinions with 11 x 39 teeth (3.545:1 ratio). Changing the crown wheel and pinion to the 3.545:1 ratio spec would reduce revs and ālenghtenā all gears.
2) the 100/6 has a different ratio in the laycock overdrive. As far as I know the support is 28% compared to 22% at the BJ8. Changing the sun wheel, planetary gear and annulus to the Laycock Overdrive A specification would lenghten only when activated the 3rd and 4rd gear.
The effect with the change in the rear axle should bring revs down 10% from 3.500 to 3.150 and the modification of the overdrive should reduce revs down to 3.231 revs if calculations are correct.
The big question is: how will I like the side effects of these modifications? Variant 1 would also make the ridiculously short first and second gear longer. Good when everything is normal. But how about starting to drive with the second gear, especially when the oil is still cold and I struggle shifting in the first gear? Today/unmodified I can easily drive off from a traffic light with the second gear, but would this also be possible with the 3.545:1 ratio? And how about a bendy road when you get out of a curve uphill with the second gear - would the unmodified 3000 engine be strong enough to still provide a sporty drive?
The second variant would keep all gears the same and only reduce revs when the overdrive is kicked in. Sounds great, but the rev-reduction is smaller than with the modified rear axle and who knows, maybe the longer first and second gear would be great and still have enough power to drive off?!
Does anybody have experience and did either the one or the other modification?
Best regards, Martin
Hi Guest!
