TR2/3/3A Red ignition light stays on...car has alternator not generator.
karls59tr
Bronze
I just finished adjusting the valves on my TR3. Now the red ignition light is glowing when the car is running? After the valve adjust the idle stayed about the same so I don't think the valve adjust caused the idle to go slow enough to cause the light to stay on? I don't think it can be a voltage control box issue as most of that was bypassed when the conversion was done. What is the best way to track down the electrical issue?
bobhustead
Does it go out at higher revvs? Put a VOLTmeter on the battery and raise the revvs to 2500 and check the voltage. Should be 12.7 to 14.2 (closer to 14.2) if it is charging. How old is the battery? Perhaps have it load tested.
K
karls59tr
Bronze
Very strange....when I started the car up today the red ign light did not stay on after start up? I installed a voltmeter in the dash when I converted to an alternator and it shows 13 when the car is running. That's a little concerning as I seem to remember it reading higher than that before. How do I know I'm not just running off the battery? Is there an easy way to test an alternator? Karl
bobhustead
If the voltage reading when running is higher that when shut off (thus reading battery alone), you are not running just off the battery. Best way to test the alternator is at an alternator shop or many parts shops can test if off the car.
K
karls59tr
Bronze
Not sure I follow. The voltmeter reads 13 when I turn the key on but when the car is running the voltage does not climb up at all. Shouldn't the voltage rise up if the alternator is charging the battery?....go up to 14.2?
Platinum
Short answer is: yes.
A VOM at he battery terminals is the best way to initially check things. Ignition off, should see 12V and a bit more. Engine running at off idle (as Bob suggests, over 2K+ RPM) you should see a voltage rise, from 12.5 to 13 at a minimum. If the regulator is working properly and VOM indication doesn't go over 13.5V the battery may be charged well enough that the regulator "sees" that. Can you turn on a load? Headlights? If so watch the VOM and see if it shows the regulator trying to compensate. Otherwise, take the alternator to a place that can test it with a load on it.
K
karls59tr
Bronze
So I put a multimeter across the battery and it showed 12.6 and when I revved the motor It showed 14.7 so I assume the alternator is charging the battery. I am using a Smith's voltmeter in the dash but it shows 13 with the key on but will not show increase in voltage when the engine is revved? Anyone know what would make the dash voltmeter not show correctly?
Platinum
Must be that the voltmeter is faulty. Are you taking the power to the instrument directly from the ignition switch? I've "added" a Smiths voltmeter to the MGB along with an alternator conversion, and it will indicate supply voltage just fine. Got it from Nisonger, matching clock, period correct face and bezel.
K
karls59tr
Bronze
Sounds like I have a similar voltmeter i got from Smiths as it it looks a lot like the existing gauges.What puzzles me is that I've had the unit for several years and it has always given me correct readings up until now? I am taking power from the ignition switch and ground from one of those brass wing nuts that attach the backing plate. i found a spare aftermarket gauge in my parts bin that tested good on the battery itself that i was thinking of installing but it does not match up with the other gauges and it stands out as not correct. I was hoping i could try and find out what is wrong with the Smiths gauge.
Platinum
Sounds like I have a similar voltmeter i got from Smiths as it it looks a lot like the existing gauges.<snip> I was hoping i could try and find out what is wrong with the Smiths gauge.
Hope you do! I'd likely disconnect it and put it directly to the battery and see if there's a change as the RPM's come off idle.
K
karls59tr
Bronze
Very Strange. I cleaned up the brass eyelet connectors at the ends of the wires with sandpaper till they were shiny. I secured the wires of the Smiths voltmeter gauge to the battery posts and the needle swung to 12.9. I fired up the engine and when it was warm I revved to 2500-3000 rpm but the gauge needle would not go past the 13???? What's up with that?
Sarastro
Sounds like the voltmeter is sticking at 13V. A common problem.
Now, back to the ignition lamp. It is connected between the battery and a point in the alternator that generates approximately the battery voltage when running. If the alternator is not generating output, that point is 0V and there is ~14V across the lamp, so it goes on. My guess is that the alternator is working but the connection on one side of the lamp is somehow grounded. Make sure all the connections are good.
Also, it's best to do the tests suggested by Dr. E with an analog meter. The digital meters can be upset by electrical noise in the car's electrical system. But since you are seeing a sensible voltage, 14.7V, it's probably OK. Usually noise causes it to give nonsense indications.
K
karls59tr
Bronze
I should have mentioned that the ignition lamp is no longer staying on. It goes out once the engine starts. My concern now is why would the voltmeter gauge stick at 13 when it is installed in the dash but when the gauge is removed and wired 'directly to the battery' it does not stick at 13 but will show higher voltage when the engine is revved? This is a newer Smiths voltmeter that I replaced the ammeter with when I did the alternator conversion a couple of years ago. It.s been trouble free up until now What causes the voltmeter to stick at 13 when it is mounted in the dash?
K
karls59tr
Bronze
I guess "stick" is the wrong term. I should have said "stays" at 13. The voltmeter gauge works fine when it is not in the dash but tested out of the car. This voltmeter is not an old unit. It is fairly new and has worked flawlessly until recently.
Platinum
Are you SURE you're connecting the gauge to a WHITE wire from the switch and NOT a GREEN one?
K
karls59tr
Bronze
Well I pulled the gauge consul out to have a look and found that the brown/ white thick wire and thick brown wire had melted against the black wiper motor switch ground button wire. I joined these two wires together when I did the conversion to the alternator as per British Wiring kit instructions. I found the instructions for the kit and it says to join the the thinner brown/blue wire to the thinner brown /white wire. That connection looks alright. But there is no mention of joining the plain brown thicker wire toto the thicker brown and white wire? I may have screwed that up but I'll have to double check with British Wiring.
J TR2/3/3A Red ignition light stays on Triumph 7
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
K TR2/3/3A Red ignition light stays on...TR3? Triumph 6
M Red dash ignition light glowing very little Spridgets 16
L Red Rubber Brake Grease Austin Healey 2
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
C Spitfire Red painted engine number Triumph 3
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
AngliaGT Red MG Spotted 0
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
B TR6 Source for Carmine Red Triumph 4
boxofparts TR2/3/3A TR3 Spotted Petoskey Michigan Red and Wedgewood or Powder Blue Triumph 1
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
J For Sale Early 70s TR6 seats in new red vinyl, with new tracks, $500 OBO Triumph Classifieds 0
T 1993 xj v12 red hot catalytic converter Jaguar 6
C How best to restore red script on valve cover? Austin Healey 7
M TR2/3/3A Red or Blue Loctite Triumph 1
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A generator red light deal Triumph 6
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
Joe Schlosser Red Samples Spridgets 5
Alfred E. Neuman Red MGA MkII Spotted 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Red TR3 on the Bachelor Spotted 1
HealeyRick "Cherry Red Austin Healey" Austin Healey 8
JPSmit Red Rubber Bumper Midget Spotted 0
H Red radiator guard reattachment question Austin Healey 10
C For Sale 1965 TR4 Red - Black Interior Triumph Classifieds 4
T Colorado Red Vinyl Interior Austin Healey 6
Pythias For Sale The Red Thing... Make Offer.. Spridgets Classified 0
AngliaGT Red Big Healey Spotted 0
Sarastro Red TR3 in Long Beach, CA Spotted 0
S Colorado Red - is there a close approximation in rattle can? Austin Healey 4
P TR6 Purple/Red wires & mystery bulbs Triumph 17
mrv8q TR5/TR250 Red 250 for Christmas morning! Triumph 10
C TR5/TR250 Red Master Cylinder Tag Triumph 4
R Donald Healey's red '53 Coupe to be auctioned Austin Healey 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
J TR6 What are Original TR6 wheels with Michelin Red Lines worth? Triumph 11
NutmegCT TR2/3/3A Service Instruction Manual [the "red book"] Triumph 3
PAUL161 Regency Red Paint Jaguar 4
S Red Fan Shroud BJ8 Austin Healey 2
PAUL161 Jaguar Regency Red Jaguar 4
PAUL161 Red Line Oils MGB Transmission? Racing 13
