TR2/3/3A Red ignition light staying on....alternator conversion.....voltmeter gauge
karls59tr
Bronze
The alternator is a British Wiring unit and has been working well for several years. Lately the red ignition light has started to flicker and now is staying on.Recently when I drove the car it has been stalling out at stop signs and low idle which leads me to believe I am running on the battery only? I am using a voltmeter gauge that used to give readings in the 13 to 14 volt range when running but now shows just above 11 volts. However when testing the battery with a multimeter I get 12 volts at the battery and with the lights on for load I get 14.64 volts? Electrical is not my strong point. Any advice on how to proceed testing is most welcome. All connections are clean and tight and all grounds are solid ie to firewall and engine and at starter and solenoid. I do not know the quality of the voltmeter? Maybe I should disconnect it entirely to rule it out. Karl
Check voltage not running no load.This should be around 12 to13volts.
Start engine and voltage should go up 13-14volts.Turn on lights etc and voltatage should remain around 13.
Sound like the light is doing its job,indicating no output.
the ignition light wire to the alternator grounds the bulb circuit with no output,lighting bulb.When generator outputs12v there is no ground and light goes out.
Tom
Tom
Thanks for the input. The problem turned out to be at the back of the ignition key switch. There is a bundle of white wires held down by a tiny screw. That screw was extremely loose causing the red light to flicker and sometimes to stay on. I tightened down the screw and problem solved. I had to pull the glove box out and stick my head in there to see what was going on. :D
