MGTF1250Dave
Aloha All,
For the second time in a short period of time, probably around 1000 miles, number four exhaust valve has eroded resulting in little or no compression. This is on my 1250cc XPAG engine in my TF.
About five years or so I had the head rebuilt using new stelite faced exhaust valves, hardened valve seats and manganese bronze valve guides. The larger diameter valves for a TD MKII/TF head were installed in my head that was originally fitted on earlier TD XPAG engine. The head replacement was only discovered after I purchased the parts and delivered everything to the machine shop. Help from this forum confirmed the casting number on the head was not original to the engine, but compatable.
After reassembling the engine things seemed fine. After about 1000 miles, I noticed a lack of power and a compression check showed very low compression on number four cylinder. I replaced the exhaust valve that was badly burnt. The replaced valve again burnt after about 1000 miles. Examination of the other exhaust valve revealed that number two had some erosion and would probably burn out soon.
I would like to correct what ever is causing these valve to erode so quickly. Any suggestion as to the cause and how to fix it?
Mahalo.
Mahalo.
Hi Guest!
