Receding Brake Pedal
SteveHall64Healey
Over the summer driving season, I noticed that the brake pedal began to sit lower and lower as the weeks progressed. At the end of the season in November it sat about 1” lower than the gas pedal that it had been aligned to a year ago.
I have no fluid leaks anywhere in the system.
I am able to adjust the brake pedal back to the same level as the gas pedal, but would like to understand why it has apparently receded.
Thanks,
Steve
John Turney
Re: Receding brake pedal ?
Disc brakes are self-adjusting, but the drum brakes require adjusting. that is probably why.
British_Recovery
Bronze
If you say you can adjust it back to level, how are you doing that? If the rod going into the master cylinder is threaded, maybe the lock nut loosened and the rod rotated.
S
SteveHall64Healey
Hi John, I have adjusted the rea brakes and it had no impact on pedal position. I've had the front calipers off and given them a good cleaning. Neither had any impact on pedal position.
S
SteveHall64Healey
The brake pedal has an adjustment mechanism allowing you to bring it up or down by an inch or so in each direction when the pedal is at rest. It is held in place by a nut at the end closest to the pedal. That nut has been on firmly all the time...
Madflyer
You might check you master cyl it may have fluid on the other side of the piston. Is the peddle still hard and does the peddle go down if you hold pressure for a time?? Madflyer
S
SteveHall64Healey
I checked the master cylinder this morning and there is no fluid between the cylinder and the pedal - no leaking whatsoever. I can pump the pedal up rock hard and hold it for several minutes, with considerable leg pressure, and the pedal remains very firm.
roscoe
Can you pull the master cylinder rod so the pedal resumes it's original position. Maybe the return spring is broken or simply worn out.
RTaillieu
Steve,
By your name it looks like you have a '64 BJ8?
Check your servo for leaks. both vacuum and fluid.
Rick
steveg
Steve,
Rick
IIRC quite a while ago on the email list some folks talked about the servo diaphragm leaking, causing it to 'eat' brake fluid. Rick's idea sounds like the best one so far.
S
SteveHall64Healey
There are no visible leaks or traces of old leaks anywhere in the system. The level of fluid in the reservoir has not dropped. I replace the servo last August with a new one, and the system does not appear to have any leaks.
steveg
Steve,
If the level in the reservoir isn't dropping at all, then fluid must be passing by the seal in the master cylinder, allowing it to gradually settle down.
Have you replaced or rebuilt the MC?
A Healey friend tried to use a Wilwood .7 MC on his 4-wheel disc-braked 100-6 and had a similar problem - he had to pump the brakes to get them to work. He bought a .7 Girling MC from Pegasus, installed it, and hasn't had any problems since. There was something wrong with the Wilwood and he returned it.
CaptRandy
Did you ever have the rear drums cut? They could have high spots. Find an old codger shop that can actually do mechanical work.
RTaillieu
Steve,
Disconnect the vacuum line from the manifold and cap off/plug the manifold fitting. See if you notice any difference in the brake pedal.
If you're not noticing any fluid drop in the reservoir then the hydraulic side isn't leaking.
You could still have a problem in the master cylinder like the other Steve mentioned.
Bob_Spidell
The brake pedal should have a pretty substantial return spring; I can't think of anything that could overcome this spring and 'suck' the pedal down. Even if the system is devoid of fluid the spring will return the pedal to its normal resting height. Is the spring installed and not broken? Am I missing something?
What usually fails in a servo is the 'gland' seal; which seals the hydraulic part of the servo from the air/vacuum part. When it fails, the air/vacuum part sucks fluid, which can work its way back to the intake manifold, causing white smoke from the tailpipe (not indicating your car has a new pope).
S
SteveHall64Healey
Hi Bob,
There has been no loss of fluid - the reservoir has remained at the full level. If this were the case, I should see some drop on the reservoir...?
S
SteveHall64Healey
I had the opportunity to look at the master cylinder:
1) there is no fluid leakage at the MC
2) the cylinder fully returns when you take foot off the brake - ie return spring appears to be working
3) there is very little slack (1/8") between touching of brake pedal and initial movement of the cylinder
And, there is no drop in the reservoir level....
Also, the servo is the Lockheed type (I gave up on trying to rebuild Girling units after two units, two attempts by me and two professional rebuilds) with about one month of use on it before being laid up for the winter. At the end of the driving season, I had the recessed pedal issue, but had very good brake boost - just as good as my 2016 Wrangler.
John Turney
Thanking outside the box: Are you sure it was the brake pedal lowering and not the gas pedal rising? Your original description compared the brake pedal to the gas pedal. I could see slippage in the linkage for the latter causing it to rise, but we're not coming up with an explanation for the brake pedal slipping down.
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
LAW75 BJ8 Brake Lines Austin Healey 2
A Brake Master Cylinder Freeplay Austin Healey 11
T TR2/3/3A TR3A Disk Brake Question Triumph 10
D Brake Lights Austin Healey 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
