Rebuilt Damper with fan eliminator kit
Brosky
I nearly lost this kit in all of the paper wrapping stuff that I was collecting. I had it in the box with the damper to be balanced along with the clutch and just found it last night when I was clear coating the damper.
I got this on ebay. Nice package and it fits great.
Platinum
Paul said:
...found it last night when I was clear coting the damper.
w00f. Ya gonna WAX it when you wash the car, too?!? :smirk:
Did you have a lot of model kits as a kid? :devilgrin:
...meh. My ~green~ is showin'.
2wrench
Y-e-a-h, Doc, welcome to the club.
I just don't understand why Paul's damper looks
so good. Mine was supposed to have been done at the
same place. It sucks compared to his.
Paul, did you paint the white markings yourself?
BobbyD
Paul,
Is that Rick Patton's fan eliminator or has someone on eBay ripped off his design....right down to the two little indents on the back side of it? If it's not his, it's a perfect copy of the one he's been making and selling for about 3 or 4 years now.
Brosky
Brosky
It's Rick Patton's kit.
I painted the lines.
I had a LOT of model cars as a kid.
I have never really grown up.
Trick6
Paul. The damper does look nice. Painting the lines white will help when setting the timing. I get ou the old white caulk and smudge it on and wipe it off which leaves the caulk in the grooves. Nice touch.
DNK
Gang, instead of the chalk trick you can also use gel pens,if you can find white,and do the same trick. Might stay longer. Try it on the dash knobs too.
tr6_easyrider
Just a heads up Paul, When I installed Ricks Eliminator Kit,
it bottomed out on the crank, so the damper was loose. I discovered this, because I had to go back into the timing cover to replace the crank sleeve, do to an oil leak. He remachined the donut a few thousands and it was good to go.
Joe
Brosky
Brosky
Joe,
I'm dense today, so forgive the questions. What bottomed out? Was the big round spacer too thick? If so, the bolt would not go into the threads on the crank, right?
But from what you're saying, it bottomed out? Do you mean that the bolt bottoms out inside the crank, before it draws the big washer and damper down tight?
tr6_easyrider
The center of the spacer that is machined, to slip over the end of the crank, made contact before contact with the damper, so the damper was floating free on the crank.
The bolt did not bottom out, the spacer was not machined deep enough over the end of the crank.
Is that a better picture?
I noticed he is now using a flat washer under the bolt, mine came with a lock washer.
Brosky
Brosky
Duh....now I got it.
I think that I'll be going down to do a trial fit on this assembly tomorrow.
Yes, the only washer that came with the kit is flat.
MTribe
The damper looks great... sorry if I'm slow on the uptake, but is there a way to rebuild it? The rubber in mine was chipping away on the outside, but the core looked OK, so I decided to just keep it as is.
But haven't put it on yet... any advice appreciated! Thanks.
Steve
MTribe
Oh, thanks Paul... that link goes to this thread. Is that intended?
sixer
Joe,
Rick Patton here. On your eliminator kit there were two issues. The first was that I didn't machine the pocket as deep as usual and the second is that the length of the nose of TR6 shafts vary a bit as they are cut to length with a saw. If you look at the end of most TR6 cranks you can see the saw marks. Since then I have deepened the pocket and as far as I know you have been the only one with that problem. Now they are all CNC cut so there are no variations. If there ever is a problem with a fan eliminator kit let me know and I'll gladly take care of it.
Rick Patton
75 TR6sci
https://pattonmachine.com/
tr6_easyrider
Rick
I should have explained my problem better. How lucky can one be, to be the only one with this problem. Your kit saves a lot of time and effort. And it certainly dresses the front of the motor. And I would recommend your kit to anyone. Thanks for explaining what I should have .
DNK
Rick- Glad to see you've come over to the dark side too
2wrench Damper to be rebuilt? Triumph 18
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
D The best place to get shocks rebuilt. Spridgets 8
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
D Starting After Carbs Rebuilt Austin Healey 30
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
Csarneson Storing a newly rebuilt engine Austin Healey 25
Got_All_4 TR6 Engine pulley dampener 69 vs 70 also new or rebuilt Triumph 1
BJ8Healeys For Sale Rebuilt BJ8 overdrive unit for sale Austin Healey Classifieds 0
steveg HD8s easily rebuilt at home Austin Healey 4
D Need to get a vaccuum advance rebuilt Jaguar 2
K TR2/3/3A Rebuilt steering has creative fix for NA worm bearing! Triumph 4
vickxxx T-Series Distributor rebuilt MG 2
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
M rebuilt gauges Spridgets 10
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
C BJ8 Rebuilt Engine and Carbs - Vapor Lock and Misfires when hot Austin Healey 7
cmacmillan TR6 now what have I done? choke on rebuilt carbs.... Triumph 6
J Starting rebuilt engine ! Austin Healey 8
F TR2/3/3A I just installed a rebuilt C39 Generator on my TR3 Triumph 11
bugedd Front end rebuilt help Spridgets 6
5 How not to start a freshly rebuilt 100/6 engine Austin Healey 30
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
T TR4/4A Breaking in a new rebuilt engine Triumph 7
Sopwith_Camel Rebuilt engine! Spridgets 8
R TR6 TR6 engine rebuilt Triumph 52
TulsaFred Rebuilt 1275 slowly getting dialed in Spridgets 14
TulsaFred First start trouble rebuilt 1275 Spridgets 29
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
M Rebuilt carbs / Idle racing to 3000 Triumph 16
PATR8 First long ride on my rebuilt 8 motor Triumph 3
S old question maybe?, rebuilt engine Triumph 3
B TR2/3/3A No oil to rockers on rebuilt TR3 Triumph 10
S Rebuilt clutch parts Austin Healey 4
M Rebuilt Seat Spridgets 1
N Checking a rebuilt engine Austin Healey 15
Rut Rebuilt Brake Calipers Spridgets 31
smaceng Rebuilt instruments...Bah! Spridgets 19
