Hello,
I am new to this site but would appreciate any collective wisdom on the following. Just finished rebuilding a 1970 Midget for my mother. Went to turn over the engine and will not go (and this is my 12th engine rebuild over the years on many different cars). Thought maybe I had had a "duh" moment in assembly so took it back out and stripped it down. Ring gaps are fine, cylinders honed, valve guides all clear... Crank spins fine with pistons out (all bolts on the flywheel etc. are the right length)and so on. The only thing left are the new rod bearings which are new from Octagon Motors here in Canada. They are standard size but starting to wonder if they are mislabeled? Anyone else ever had this experience? Any other reason anyone can think of? This will be the engines third time out of the car.
Thank you
Thank you
