TR2/3/3A rebuilding door panels
sp53
I thought I would post to show where I am at with my car and ask a couple of questions about fastening to that hard board the panels are anchored. The board I am using is surprising the same or the same as the 1950ties stuff. I bought one of those staple guns at HF that shoots ¼ staples. My concerns are filling the door card with staples like was done originally or to use more glue and less staples because my fear is at some point towards the end the board will break because of all the staples. The fiber board kinda looks like the stuff John used. I am a carpenter, but I have never used this product or work much with light weight material. I did my seat frames with ¼ plywood and have a feel for that plus they were done originally with plywood.
steve
CJD
Steve, that's looking great!
I know the factory cut out those side curtain mount holes...but I'd probably not worry about them. They never seem to be located quite right and I never saw the purpose anyway??
Skinner used glue in some areas and staples for others. Where they stapled they used plenty of them. Even with my removing and re-stapling I didn't see any weakening of the fiber board. I think either glue or stapling, or both, will work fine. The only area I might be inclined to use both would be around the glove pocket. The pocket is not pressed against the door metal and also sees a lot of use...so both glue and staples would be appropriate. Around the edges is held against the door, so it naturally gets pinched.
Love you sky blue paint!
RC64
Steve...
I rebuilt all of my interior panels and only used a few staples where the glue didn't get a good grip. Other wise it was only Weldwood Contact Cement. So far, so good.
BTW, you have excellent taste when it comes to color choice.
Rick...
S
sp53
The reason I asked is some of these original panel cards were stapled on 1 inch centers!
CJD
If you have trouble finding the white piping to match your seats, let me know and I'll sew some up for you...
RC64
My original panels had staples as well. I experimented with staples of different lengths but wasn't pleased with the results. I was using Masonite which I had a ton of around here. It is harder than what was used originally so the really short staples wouldn't hold very well. With the ones that were slightly longer the points would protrude from the other side. Since I wasn't using any padding, they would stick into the material leaving a dimple. Didn't want that. So the contact cement worked good.
Jesus
I would recommend using stainless steel staples. They are more expensive than the regular ones, but the final amount you spend is not very large.
Jesús
S
sp53
We have a fabric and foam shop in town John that has a lot of different stuff, so I will scope that out first.
Yeh Good idea Jesus I will see what they have.
I found the fiber board at HD, RC64 and it looks and feels exactly the same as the original stuff and that surprised me. I could not resist using it; it warps easily; if it is in the sun it starts to curl and I am sure it will hold water by looking at the old stuff.
Masonite is more than likely the improvement board over this stuff because it lays flat and resist water, and that is what I was going to use. Here the Masonite is 22.00 a sheet and this stuff is 10.00 and recommended for shelving. it is the cheapy and hopefully it will hold staples.
Steve
RC64
Steve
Too bad you're not close by. I have at least a couple dozen 4X4 sheets of Masonite. Several years back a small company that manufactured high end book cases was closing up their shop. Couldn't compete with the offshore companies. All their materials had to go. I paid next to nothing for the Masonite and the oak they were using was 10X3/4 and 12X3/4 and was going for $1 a foot. All of my shelving and the bases for 5 work benches are all oak. Cheaper than using plywood.
Rick...
malbaby
I used MDF...medium density fibreboard together with a thin foam under the vinyl....masonite was too hard....mixture of contact adhesive and shortened staples for fixing.
S
sp53
Well Malbaby I got the fiber board and the thin foam now I am waiting until after the holiday to check out the local stores for some 5/32 stables because HF only had 1/4, but did fine some online for 13.00. I also used split rivets for cubby boxes and the rivets are not around locally but found a good deal on line. I have to admit the rebuild is more time consuming than I thought it would be.
Steve
CJD
What did you decide to do for padding on the panels? I think the factory just used some cotton batting, like 1.8" or so. Moss and TRF use about 3/8" of foam. Skinner used a stick-on 1/8" foam, which seems to do a good job of duplicating the look of the original. Moss and TRF always look "over padded".
malbaby
I could not find short enough staples so I carefully used a disc sander on blocks of staples...lost some, but overall had enough to use successfully.
PeterK
For padding, I used 1/4" foam with scrim, a cloth backing. Also used hardboard(masonite), Weldwood and 5/32" staples but I could only find the 5/32" in galv. not SS.
CJD
While looking for cover material, I did see that JoAnn fabrics has 1/4" foam padding, original looking cotton batting for padding, or 1/8" stuff made to be backing for something (unknown to me not being a real seamster) that would work too.
S
sp53
The guy at the foam shop sold me some 3/16 foam that was on a roll. The stuff was black with a flat side and ruff side. I wish I would have used a grinder on my box of ¼ staples. I ended up buying 10,000 for 13.00 and free shipping; I will see when they get here if they work in my HF gun. I still have my grinder!!
steve
S TR2/3/3A Rebuilding a cylinder head Triumph 10
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
djackson Rebuilding 100/6 Transmission Austin Healey 6
bighealeysource Rebuilding BN2 generator Austin Healey 5
Xte Rev counter rebuilding ... Austin Healey 2
J TR6 rebuilding tr6 rear hubs Triumph 13
H head rebuilding mods Austin Healey 15
