twas_brillig
We have a nigh-on-perfect BE body tub (owned since 1972, never been on the road; spent a year at a body shop recently) that I'm hoping to get to doing final assembly on this winter.
It has a Rivergate Datsun 5 speed and the head has been redone with hardened inserts etc. but the block is pretty much toast (a bit of a surprise and disappointment).
Touch wood, we'll be dragging it indoors sometime in the new year, pulling the engine, and getting it rebuilt. I would appreciate thoughts as to what improvements should be made. And let's not worry about carbs at this point.
I believe that I've got the good rear main seal from Rivergate, and am thinking:
Head: switch to ??? rockers (because they look good) and a ??? head gasket (because it works)
Ignition: Pertronix (we'll be staying with positive ground)
Exhaust: we have an LCB header
Shortblock: your suggestions??
- stock cam(I'm a cheap bahstead),
- get it balanced
- spin on oil filter
- look at upgrading the harmonic balancer
- perhaps use ARP bolts wherever I can afford them
I figure I'll change the rockers on the head to
- get it balanced
