TR6 Rebuilder or replace wiper switch?
nichola
Bronze
Has anyone rebuilt the original wiper switch? Or, has anyone replaced it with a nice alternative?
I’m testing the old stuff as I go through harness installation, and this doesn’t seem to work.
Shouldn’t I see continuity from the inside blade (nearest the female connector) to one of the outside male blades?
steveg
This rather lengthy Triumph Experience thread explores the ins and outs of building your own using the Painless 2-speed wiper/washer switch and two relays.
nichola
nichola
Bronze
I am going with double toggle switch setup, as described in Dan Masters, sourced from wiringproducts.com...
They will put proper labels on it.
nichola
nichola
Bronze
Hold on folks... scratch that wiringproducts.com "endorsement" above. Although they sent me a toggle switch and connectors very quickly, they have not sent the dual toggle panel. No response to email, voice mail box full, nada. I checked for comments on the company and those are very negative. I will contact PayPal for resolution. If anything changes re the order I will advise.
TRopic6
Hi Nichola,
I've been able to rebuild several original switches to get normal turning force and no slipping between the metal spacer and actual switch. I pried the back off with brute force and a screwdriver, but someone else used a screw to lever the back plug out. Check this TRExp thread out and give it a shot. Unfortunately there is some risk that a 40+ year old plastic part might break.
> TR6 Wiper switch moving at dash : TR6 Tech Forum : Triumph Experience Car Forums : The Triumph Experience <
I'm not sure there is any direct replacement switch, as the low-speed brush has to be grounded in the OFF position to provide regenerative braking to keep the motor from 'coasting' past park. There was a thread on using a generic switch and 2 relays, but it was easier for me to work on the original switch. The one on my low-miles 75 TR6 is so hard to turn I'm afraid the plastic shaft is going to snap. That's my next project...
Jeff
nichola
nichola
Bronze
Thank you Jeff. I will try taking that old switch apart, but if my toggle switch panel ever arrives from wiringproducts.com I'm not opposed to going that route instead.
nichola
nichola
Bronze
Well, once they located my order at wiringproducts.com it only took two days to get the switch panel to me... about the same timeframe as the two other orders I placed with them. So, pretty satisfied with that. Using two on/on SPDT toggles as described in Masters’ book. Still pondering what finish to put on the dash. Probably start with satin black, invoking the KISS way of doing things.
R Brake Servo Rebuilder Austin Healey 14
steveg Altette horn rebuilder Austin Healey 5
PAUL161 General MG Carb Rebuilder Near Tulsa Oklahoma MG 1
GTP1960 General TR Great SU Carb rebuilder instructional Blog. Triumph 5
S Looking for a reputable engine rebuilder in Atlanta, GA area Austin Healey 6
TR4nut TR2/3/3A TR3/4 Water Pumps - Anyone have the ebay rebuilder contact info? Triumph 5
stretchit2 Recommendations for Engine Rebuilder Austin Healey 3
PAUL161 Carb rebuilder? Hap? MG 5
H Carb rebuilder recommendations Austin Healey 4
Gliderman8 Brake booster rebuilder Triumph 5
H Carb rebuilder recommendation? Triumph 5
Kleykamp Temp gauge rebuilder?? Triumph 6
tahoe healey fuel pump rebuilder Austin Healey 2
bugedd Tranny Rebuilder Spridgets 17
arfamoe Engine rebuilder needed in Ontario Canada Spridgets 2
Moseso Shock Rebuilder Question Triumph 8
Moseso For the next steering box rebuilder Restoration & Tools 1
Moseso For the next steering box rebuilder Triumph 0
mabbott TR6 Rebuilder of TR6 Strombergs? Triumph 11
jlaird A arm rebuilder Spridgets 3
R Rocker Assembly Rebuilder Austin Healey 6
jlaird Lucas rebuilder Spridgets 8
Brosky Distributor rebuilder - who, where? Triumph 5
C Hub Rebuilder Contact? Triumph 0
Brosky Recomendations for Distributor rebuilder Triumph 5
S introductions and tips for 1st time rebuilder MG 9
bighly Any Recommendations for Distributor Rebuilder? Austin Healey 7
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
V MGB Replace late intake manifold angled breather with early model straight? MG 1
W replace rigid master cylinder lines with flex. Spridgets 2
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
B A plan to replace BE floor pans Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
J TR2/3/3A replace brake and fuel lines? Triumph 4
J TR2/3/3A Replace rusty sills? Triumph 10
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
JPSmit replace shocks in pairs? Spridgets 7
JPSmit When do you replace things? Restoration & Tools 22
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
AUSMHLY When to replace spark plugs Austin Healey 1
drooartz MGB What to replace when engine is out MG 10
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
