Rebirth
catfood
At last I'm on the home stretch. After four years of fun (and a lot of blue language) I can finally see the light at the end of the tunnel.
Sunday was spent refilling the car with fluids and checking for leaks - all good after I remembered to put the fuel tank drain plug in!
Carbs and ignition had been rebuilt and bolted on. With no setup I decided to turn the key and see what happened and to my amazement she fired first time (admittedly only for a few seconds before stalling). So next weekend will be getting the carb and ignition setup right.
She's booked in to JME in a few weeks to do the final fit and paint for the external bodywork then its just lights and interior and I will have a drivable car again.
Whoopee!
YAY!!! I know you're beyond chuffed!
Nahhhhhh,
Go the Revival................you'll love it!
You are indeed right. The brain said Revival but the fingers typed Festival of Speed. The Revival is my 'Target'.
A big 'Thank you' should go out to Basil and the rest of 'Team BCF', without this Forum and all the expertise within I would have thrown in the towel a long time ago. The search facility has saved my bacon more than a few times!
:thankyousign: :bow:
Have fun !!
