fordtrucks4ever
Today I planned to get rearend out of car. These 1/4 elliptics are a pain when all rusted and stuck. The long front bolts ahead of large u bolt snapped off on left side. Right side came out, not without difficulty. I had to raise left spring, and torch off the lower rivet head and broken stubs of bolts so it would pullout. Driveshaft was still connected, which made it easy to pull axle back and set in lap then lower to floor. The body is sitting on a roll around about 30" off floor. Now I see how bad these cars rust. Looks like a lot of panels welded to make any stength. But most will need to be replaced. Back to start drilling spot welds and peeling apart panels...Well they used to be panels. Maybe just shake a little bit and see what is left.
