AUSMHLY
Hi all. 64BJ8. I've attached a photo of my rear wire harness. I need some help with which wires plug into the harness.
Right tailight: bullet clips.. solid red, solid black and solid green.
Harness wires that extend to the right: bullet clips..white with brown strip, solid red. Ground clip.. solid black. (no black bullet?)
Harness wire in the middle: 2 solid black wires join with one ground clip.
Bullet clip..solid red and solid black...for the license plate light.
Ground clip, 1 solid black wire
Left tail light: bullet clip..solid red, solid green.
Harness: bullet clips..solid back, white with purple stripe, 4 way bullet with 3 solid red wires attached and one opening left.
Right tail light...red to red, green to wht/brown, black to ?
Left tail light...Red to red? Green to wht/purple?
Where do the black grounds go? Screwed to the trunk lip, inside?
Thank you, Roger
Thank you, Roger
Hi Guest!
