Hey Guys, I created the tool as you've seen to press the hubs from the axles in a similar way as the Churchill tool. I assembled and installed the tool, tightened and struck the bolt to shock and free the taper. Sometimes it may take a couple of times tightening and striking the bolt. If you are really lucky it will separate during the tightening operation. The tool works on any of the triumph hubs with the external threads that the nut will fit late TR3 and 4 with the live axle.
I had failing seals (like wood and were passing gear oil) that required replacement, there was nothing wrong with the bearings.
Please let me know if I did or did not answer you question.
Dave
