Rear Springs - Aftermarket or buy an old used pair
Csarneson
I'm restoring a ratty BN4. One of my old springs was broken and then welded, then broken again at some point. No surprise that the weld broke. The previous owner was a welder so every time something came loose or broke on the car he welded it. The old adage that "when you're a hammer every problem looks like a nail" comes to mind. That's a longer story but I need at least one spring.
All the other spring threads talk about the aftermarket ones sag quickly. If you had only one usable old spring what would you do to restore a driver-level car?
Buy a pair from moss or AH Spares? Try to find an old used one? Try to find an old matched pair? Budget is a factor but I don't want to be short-sighted either. Thanks.
Can a specialist replace just the broken leaf and then re-curve my old set?
Chris
ps> I should add a giant thank you to this forum as a whole as well. It's been invaluable. Thanks for being so generous with your time and advice.
Csarneson
Csarneson
Cape doesn't appear to sell leaf springs any longer. I also can't find any reference to that spring manufacturer on google.
Keoke
Buy a new set-----:encouragement:
maxwedge5281
i bought a set of new rear springs for my bn7 from jule enterprises in canada. they have been on my car just over a year. good ride quality coupled with the putzke fahrspass tube shocks on front and rear...
I've had a set of Moss-sourced springs on my car since the early to mid 80s, and it still looks to be sitting level. Given their weight, I'd be reluctant to order something like that from any vendor that required me to use International $hipping, particularly if I was trying to save money.
You might check your local Yellow Pages to see if there's a spring shop in town, you might be surprised to find them the most cost-effective yet (and you have one good spring as a pattern). I'd be sure to get them to verify that they can produce the correct deflection rate, as the ride height can be fine-tuned if they're willing to work with you.
Csarneson
Csarneson
I really hadn't considered that somebody reasonably local could repair mine. Shockingly there's a shop 90 miles away in one of the towns I visit often for business. I'll take my springs next time and check them out.
As always you guys are full of creative ideas and insights.
i nearly bought several Healeys over the past 15 years. I don't know that I could have successfully restored a car without YouTube and these web forums.
John Turney
I installed my Moss springs in the late 90's and they're still fine.
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
R TR2/3/3A Replacing rear springs Triumph 51
Michael Oritt Rear springs Austin Healey 18
Keith_M Bugeye rear leaf springs Spridgets 19
M TR4/4A Rear coil springs for TR4A Triumph 4
D TR6 Rear springs Triumph 6
D MK2 rear springs Jaguar 3
C TR5/TR250 Rear springs Triumph 1
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
K TR2/3/3A New Moss Rear Leaf Springs Triumph 7
K TR2/3/3A Moss rear leaf springs? Triumph 19
P Bugeye rear brake springs??????? Spridgets 5
maxwedge5281 rear springs on big healey Austin Healey 4
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
Mickey Richaud MGB-GT GT Has New Rear Springs! MG 1
Jeepster BJ8 rear leaf springs Austin Healey 2
Lin Reinstalling rear springs and axle in 64 MK2 Jaguar 1
P BJ8 phase 2 rear leaf springs Austin Healey 2
D Replacing rear leaf springs ? Triumph 6
CanberraBJ8 Rear bump stops vs springs Austin Healey 3
J Rear Springs Midget Spridgets 10
vette Next Question on Rear Springs Mounting Austin Healey 2
K MGA MGA rear springs MG 7
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
S MGB-GT Using MGB GT rear springs in an MGB? MG 4
jackq MGC MGA rear brake shoe keeper springs..and Two MGCs MG 2
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
M zinc leaves in rear springs bn2 Austin Healey 5
M MGB MGB rear springs VB Thailand made MG 3
boxfullofyertoys Front and Rear Springs...Repair? Replace? Spridgets 12
B MGB Wanted, Rubber bumper MGB rear springs MG 0
Hairyone bugeye rear springs Spridgets 1
Tom Rynne Up-date-Winner's Circle Rear Springs Spridgets 4
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
mountainman TR2/3/3A TR3 Rear Springs Triumph 14
T Question regards Quarter Elliptic Rear Springs Spridgets 6
tahoe healey re-arching rear leaf springs Austin Healey 27
M Bugeye rally spec rear springs? Spridgets 9
Hairyone BE rear springs Spridgets 10
H Longbridge 1004 Rear Springs Austin Healey 2
B 3000 [not BJ8] Rear Springs - too stiff - why? Austin Healey 6
S Sprite mark 4 rear brake shoe springs Spridgets 4
rchakr Changing Rear Springs Triumph 6
Johnny AH 3000 BN7 rear leaf springs modifications. Austin Healey 4
Atrus A few rear suspension Q's [springs & bushings] Spridgets 10
B rear leaf springs Spridgets 14
MGBGT_noob MGOC Rear Springs MG 1
