Bushings reduce lateral movement of the chassis over the suspension. This makes handling more precise. The stiffness of the ride is controlled by the springs, and to a certain degree shocks and anti-roll bars.
The problem with stiff rear springs in the B is the live axle. Putting stiff springs on a heavy, solid lump like that will make it choppy on rough roads. Stock springs with slightly more firm fronts and a larger anti-roll bar (sway bar) are a good setup for most performance applications. I've found stock springs all around to be good for me.
