Hi All,
I am looking to refresh the rear suspension on by BT7. The manual describes removing the shock absorbers as a simple 3 step process:
1) Remove the nut hold the shock lever to the link arm
2) Remove the bolts securing the shock body to the chassis
3) Remove the the shock from the link arm
Easy! Except I can't remove the lever from the link arm or if I undo the link arm nut the link arm from the chassis.
So in the attached image how to you actually separate the shock lever arm and/or the link arm?
Appreciate any suggestions.
Cheers
John
Cheers
John
