bugedd
I just put new bushings in the rear radius arms and before I put them back in, I have a question. Where they attach at the rear axle there is some space between the metal spacer for the bolt and the axle, about 1/4" on either side. Now that seems like it will allow the rear axle to float around side to side a bit. Should I put some washers in there to take up the slop? Or is that slop in there for a good reason?
Hi Guest!
