I have the rear radius arms removed from the E-type rear suspension and need to replace the two bushings in each arm. What is the easiest way to remove the old bushings?
I have a 12 ton press but don't have punches of the right size. Until I purchase a lathe, I need an easy way to make or find the right size punches. One needs to be about 3 inches in diameter and the other about 1.75 inch diameter. I could make them from plastic but I have no idea whether it would be strong enough for this job. Any suggestions? (Yes, I know I could take them to a machine shop, but what if I were in the middle of a desert, etc.!)
Bill C.
Bill C.
Hi Guest!
