tahoe healey
I've mounted a new rear engine oil seal and I'm making a gasket to fit between the steel plate and the engine. Do I mount the gasket behind the seal or cut around it? If it is mounted behind, it will not make as good of a seal if I match the pattern of the old seal (part will rest on the gasket and part will not - the gasket is paper thin). I can alter this to go completely around the crankshaft and behind the oilseal which is bolted to the engine block. Any thoughts?
