Deleted member 8987
Absolutely.
Now, if brakes are dragging or hanging up, maybe two hands, but you should be able to rotate the shaft, neutral, e-brake off, wheels at lease .002" off the pavement.
If you cannot, stick a big screwdriver through the space in the u-joint/yoke to pry it over.
Then see if it's stiff 360 or just a little.
Hi Guest!
