Chad Donner
Has anyone continued to have issues with a rear main seal leak with the Moss main seal retrofit?
I haven't started the car yet, just primed the pump and cranking it over with the starter and i notoced a couple days later i had drips coming from the bell housing.
Is it possible that the drain tube off the bearing cap sitting below the oil level is causing oil to back up into the rear main seal cavity? ie..the head pressure of the oil draining from the bearing isn't enough to overcome the surface tension of the oil with the drain pipe below the oil level?
Thoughts?
I'm gonna try to post a picture as to what i am thinking about the drain pipe.
Thoughts?
