Woodie
Ok I tried to reconnect the wires in the trunk, the PO had disconnected them all. After 1 hr I had the drivers tail light (top Bulb) lit. The passenger side bulb wouldnot light, yet this is thefeeder wire to the drivers side. I found an extra double connector and a male male jumber and ran an extra wire from the drivers side to the passenger side. The passenger side now lights up. I cannot get the brake or turn signal lights to work. About the turn signal lights, does the emergency flasher switch need to be connected (correctly) I do not get a click out of either flasher unit. On the brake lights, what does the brake light switch look like and where is it ??
Hi Guest!
