TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A??
Popeye
Hi all,
What is the easiest way to differentiate a TR4 "deep-dish" rear leaf spring from a 4A leaf spring?
On my car, which I bought in essentially non-working order, the aluminum spacers between spring and axle are different on the left and right sides. I believe the passenger side to be correct. (See https://www.britishcarforum.com/bcf/showthread.php?106608-TR4A-rear-leaf-spring-distance-piece). Also, the driver's side spring was mounted incorrectly. (https://www.britishcarforum.com/bcf/showthread.php?105071-TR4A-solid-axle-rear-leaf-spring-question)
A little research suggests the driver side spacer is from a TR4: https://www.britishcarforum.com/bcf/showthread.php?49262-TR4A-solid-axle-assembly/page2, post by PeterK: the left side of the photo shows what I have on the passenger side, the right side what I have on the driver side. To add to the mystery, the driver side shock link (the one connected to the "suspicious" spacer block) was broken - perhaps due to the incorrect spring / spacer block.
The two springs look similar; same number of leaves, same shape when unsprung, both fit on the TR4A solid axle frame.
Bottom line, I may end up ordering new springs and blocks from the UK (SC Parts has springs and spacer; Rimmer and Revington the springs only). I suspect the shipping costs would be quite high - thus it would be nice if I could use what I have, perhaps ordering only the spacers from SC.
Thanks!
Popeye
Popeye
P.S. For what it's worth, the following are the part numbers as best I understand:
TR4
Spring: 209964 ("Deep dish); 208636 Driver's side, 208637 Passenger side ("Standard", before CT23383)
Distance pieces: 209962 (RH), 209963 (LH) - per technical manual, or 137634 (LH), 137635 (RH) per the Rimmer website. (Note, I'm not sure if RH is driver or passenger side, given it is a British book and website.)
TR4A
Spring: 212113
Distance piece: 142277, per Rimmer and TRF. Per PeterK above, and what I have on my passenger side, the parts are marked 212225.
TR3driver
Great Pumpkin - R.I.P
FWIW, the TR4 SPC has the 137634/35 numbers. I'm fairly certain the distance pieces don't change sides when the driver does (meaning RH is always RH even if the car is LHS).
And the ones I have laying around, which I'm fairly certain came from a TR4, definitely look like PeterK's TR4 photo. The shock attachment point is not centered on the piece, which I think is the LH/RH difference.
The illustration in the TR4A SPC looks exactly like PeterK's TR4A photo, even though it gives the 142277 number.
PeterK
I might have a usable TR4A piece around if you need one. Can't promise condition but I will look if you're stuck and need one.
Popeye
Popeye
Thanks Randall, Peter. Let me check locally on the distance piece, if not I may take you up on the offer!
However, a fundamental question: would a TR4 spring physically fit on the TR4A frame? The mis-matched distance piece makes me a little nervous - could this indicate mis-matched springs? Both springs "look" the same (i.e. hold them side-by-side, they have the same dimensions and curvature), and both sides mounted easily.
Unfortunately I did not pay enough attention to the car before disassembly, whether it sat straight or not.
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
H rear leaf spring to chassis bushing Austin Healey 11
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
R Rear Leaf Spring Removal Triumph 10
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
Tabcon Rear leaf spring bush size? Triumph 21
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
N Rear leaf spring brackets Austin Healey 9
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
8 Rear leaf spring Triumph 3
F new rear leaf spring disapointment... Triumph 9
Keith_M Bugeye rear leaf springs Spridgets 19
K TR2/3/3A New Moss Rear Leaf Springs Triumph 7
K TR2/3/3A Moss rear leaf springs? Triumph 19
Jeepster BJ8 rear leaf springs Austin Healey 2
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
P BJ8 phase 2 rear leaf springs Austin Healey 2
D Replacing rear leaf springs ? Triumph 6
bugedd Rear leaf install Spridgets 7
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
tahoe healey re-arching rear leaf springs Austin Healey 27
Johnny AH 3000 BN7 rear leaf springs modifications. Austin Healey 4
B rear leaf springs Spridgets 14
P Rear Traction Bars for our Leaf springs Triumph 0
malice Rear leaf swap. Triumph 8
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
AUSMHLY Rear leaf springs Austin Healey 6
Michael Oritt BN1 rear leaf springs Austin Healey 4
S Rear Leaf Springs Austin Healey 30
bighly Replacing rear leaf springs Austin Healey 10
Healey Nut Rear Wiring Routing Austin Healey 2
R TR6 Rear suspension droop restraint Triumph 0
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
drooartz Rebuilding rear axle Spridgets 10
S TR2/3/3A rear main seal is leaking Triumph 13
J TR2/3/3A TR3 Rear seat Triumph 11
T crankshaft (rear) bearing leak Spridgets 2
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
5 TR2/3/3A Seized rear brakes Triumph 9
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
