Just curious, which manual is that? Mine says 28-30 in the front and 26-28 in the rear. Same numbers in the TR3 workshop manual as well, so I'm inclined to think they are right. Never had any trouble with them (but I didn't bother with a torque wrench either).
Thanks Randall. I am using the blue TR4/TR4A manual. My torque numbers are from memory and may be off by a little. But the minimum torque for both ends of the leaf spring are 30 ft-lbs.
That just, intuitively, seems like a low torque for a 5/16 bolt. I will stick with that value until proven orherwise. (As an aside, the manual references a 1/2" bolt.)
The pin body is pretty big, 1/2" sounds about right (don't have one handy to check). But the threaded portion is smaller and also has one side cut off (to keep the flat washer from turning). The parts catalog shows the nut as having 1/4-28 threads (even though it is 3/4" across the flats).
This is from a PDF, but matches my copy of the TR4 workshop manual 2nd edition (with TR4A supplement) in the blue binder
Given the trouble many have removing that pin plus the fact that it is secured mechanically with a split pin - I never thought to consider a specific torque. In any case, with the split pin you have to tighten more or less to get the holes to line up.
...not to mention the nut isn't doing much but keeping the bushing from wandering off the pin, and keeping the center of the bushing from spinning on the pin.
