Recently pulled the rear hub and replaced the oil seal. When I reinstalled the hub onto the axel housing it appears that the bearing race extends beyond the .4000 that the manual states. Must I remove the hub and reposition the bearing? How much "wiggle room" do I have?
Question 2: I replaced the hub studs with new ones from Moss. When I attemped to install the axel, the holes would not align properly. Is this a usual occurance? Anyone have a "tip" on getting the studs and the holes in the axel to properly align?
Any and all suggestions would be greatly appreciated, I am at my wits end with this procedure!!!!!!!
Thanks,
Ray
Thanks,
Ray
Hi Guest!
