Hi Guest!
Hi Steve, I have a '59 100-6 and a '67 BJ8. This morning while on a very short drive, it kind of felt like something was wrong with the steering and then like maybe a tire was flat. I got the car home and looked at the left rear wheel and found it to be at an angle. I jacked up the car and the wheel was bing held on by ONE half loose lug nut!! The other four nuts fell onto the floor. I am still shaking from what would have happened had that wheel fallen off! The brake shoes are saturated with diff oil so I have order new shoes. I also ordered new hub studs and lug nuts. I have the bearings, seals. o-rings and gaskets in my spare parts drawer and will change them. I was able to clean up the thread on the studs with tap and dies and put the wheel back on to move the car around. I realize your post is years old but if you still have any info that might be useful to remove the shaft in order to replace everything, I'd sure appreciate it. I have the socket for the axle nut. Thanks. My regular email isbucaneer, I have the tool you need to remove the big octagonal rear axle nut if you want it. I put together a kit that is handy for removing the rear axle bearing housing and will loan it to you for the shipping cost. Or, since you are in Wilson, we could arrange to meet somewhere.
I removed the bearing housing and had a machine shop in New Bern replace the studs for me.
Once you've removed the wheel, hub and brake drum, the only thing holding the axle in place is one countersunk screw. Like the two that held the drum on.Hi Steve, I have a '59 100-6 and a '67 BJ8. This morning while on a very short drive, it kind of felt like something was wrong with the steering and then like maybe a tire was flat. I got the car home and looked at the left rear wheel and found it to be at an angle. I jacked up the car and the wheel was bing held on by ONE half loose lug nut!! The other four nuts fell onto the floor. I am still shaking from what would have happened had that wheel fallen off! The brake shoes are saturated with diff oil so I have order new shoes. I also ordered new hub studs and lug nuts. I have the bearings, seals. o-rings and gaskets in my spare parts drawer and will change them. I was able to clean up the thread on the studs with tap and dies and put the wheel back on to move the car around. I realize your post is years old but if you still have any info that might be useful to remove the shaft in order to replace everything, I'd sure appreciate it. I have the socket for the axle nut. Thanks. My regular email is
homerboy488@yahoo.com
So you're telling me that the ONLY THING holding the axle from coming out is ONE SCREW?? What about that big 1 7/8 inch nut? ONE SCREW? Come on!!Once you've removed the wheel, hub and brake drum, the only thing holding the axle in place is one countersunk screw. Like the two that held the drum on.
To get to the big nut, you have to remove the axle shaft. One screw attaches it to the hub. The big nut holds the hub on the rear end housing. Note that on one side of the car, the nut has RH threads, on the other LH threads. The nuts have RH and LH stamped on one side near MOWOG; hopefully on the side facing out.So you're telling me that the ONLY THING holding the axle from coming out is ONE SCREW?? What about that big 1 7/8 inch nut? ONE SCREW? Come on!!
Thanks, THAT I understand. The previous post made it sound like it was that one small set screw that prevented the shaft from coming out. That was ridiculous. The only thing I'll have to figure out is how to measure the .0001-.0004 on the bearing.To get to the big nut, you have to remove the axle shaft. One screw attaches it to the hub. The big nut holds the hub on the rear end housing. Note that on one side of the car, the nut has RH threads, on the other LH threads. The nuts have RH and LH stamped on one side near MOWOG; hopefully on the side facing out.
You'll need a puller to remove the hub from the rear end housing. I made a steel disk with a pilot to fit into the end of the housing with a center on the other side for the puller's threaded shaft. Think I used a two arm puller - a bit awkward with the five sided hub. Used a brass drift and a hammer to remove the bearing - taping on the outer race. If you're replacing the seal, note which way the original one is installed; spring towards the bearing. I made some drifts to install the seal and the bearing (hydraulic press, instead of the hammer). Used the press to remove the old studs and install new ones.
This is covered very well in the factory workshop manual. Pay attention to what it says about the offset between the hub and the distance piece.
When everything is put back together, the axle shaft is held in place by the screw, the two screws that hold the brake drum on and the five studs/nuts that hold the wire wheel hub extension on.
Thanks. I have a puller for the hub and will get a new caliper today. What should the measurement be?You can use an axle (half-)shaft to pull the hub. The shaft disk is rounded (crowned?); after you've removed the screw and pulled it out of the diff, turn it around to face the axle housing so that the studs protrude through the holes, then spin the nuts on and tighten them crosswise (like bolting-up a disk wheel). When you've run out of threads, undo the nuts and put a suitable sized and shaped spacer--pref. a large socket--between the shaft plate and the end of the axle housing; one more time down the threads should do it.
ps. You can use a caliper (with extension) to check the spacer depth; here's a cheapie:
6 in. Digital Caliper with SAE and Metric Fractional Readings
Amazing deals on this 6In Digital Caliper Sae Metric Fractional at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Yeah, my mistake on the 0.001-0.004 thing. I have the paper gaskets from MOSS so I hope it does the trick. I have bought numerous parts from them that don't fit. I know it happens but they seem to have a pretty bad track record. Thanks for the help. It'll be the project for today.You wrote ".0001-.0004" (1-4 ten thousandths of an inch), but 0.001-0.004" (thousandths) is more likely (sounds about right, I don't have my shop manual handy (I'll dig it up if someone doesn't volunteer it). The spacer is there to exert clamping force on the outer race of the bearing so that it doesn't spin in the hub (Tom Monaco told me he's repaired 'hundreds' of hubs). The possible problem--IIRC Steve G. has written extensively on this--is that some vendors sell a paper gasket that is so thick as to prevent the axle hub from sufficiently clamping the bearing. Some owners prefer to only use a sealant on the hub in lieu of a gasket, or to make a gasket out of thinner paper; that and the O-ring should prevent leaking (I use paper gaskets with a sealant). My guess, and it's only a guess, is that you want the gasket to be the same thickness, or just a 'smidge' thicker, depending on the gasket's composition/compressibility--than the distance the spacer ring stands proud. For example, if your spacer ring--Moss shows different part nos. for different cars--stands proud 0.002" then a gasket thickness of 0.002" would be perfect, but 0.003" might compress enough to allow proper clamping. I use Permatex #3 'Form-A-Gasket' in this type of application, as it works well and it's less likely to break off a chunk (I see no downside to using a sealant here).
I suspect this was an ongoing issue with Austin, or whoever made their live axles--MOWOG?--as the BN1s didn't have the spacer, or an O-ring, and the later cars have one for early 6-cyl cars and one for BN7s-BJ8s. The problem, besides spun bearings, is if you get a leak here it will soak your brake shoes.
