bcbennett
Hi all,
Regarding my '74 TR6:
The fuse protecting marker, parking, brake, and dash lamps keeps blowing (red/green wire to double red wires). I removed each lamp, one at a time, no help. I have examined all connections, all seem fine. When I flip the light main switch, I get about ten seconds before the fuse blows, during which time all my back lamps are dark. The license plate lamps glow faintly.
However, the circuit hooked to my driver's rear marker lamp (double red wire to socket) is hot to the touch each time I flip the switch. Removing the lamp and removing the socket from the hole does not stop the wires from heating up, and even removing the lampholder from the spade connector does not stop the wires from heating. None of the other wires gets hot.
Thoughts?
Thoughts?
