TR4/4A Rear Fuel Line Routing IRS
bammons
The PO had cut the fuel line just under the gas tank and used a long rubber hose to connect to the hard line coming from the driveshaft tunnel. I want to make a new line and am not sure of the routing so that it does not interfere with the axle/swingarm. Does anyone have a picture they could share with me to give me an idea of the routing? Bruce
Hope this photo will help you.
Perry That helps some but what I really need to see is how/where the line from the tank routs to where your picture shows. Where does it go as it leaves the tank and does it go around the side of the differential bulkwork or over. Bruce
It is different between a TR4 and 4A. Take a look at this page from Rimmer Bros showing the fuel piping:
Here is the rest of the fuel line.
OK I think I see that it is laid out different than I thought. I may not have the hard line coming from the driveshaft tunnel positioned correctly. I have the 90* bend turned toward the swing arm. It seems that in your picture it must turn down. I will get under the car tomorrow and see if I can figure this out. Thanks very much for the picture. Bruce
