Need some help as I believe I've screwed up!! I'm reassembling my rear drum brakes on my 59 BE. I beleive as you view the brake assembly the right side dust shield should have the fixed stop a 2 o'clock & the left side should be at 10 o'clock. I've assembled the L/S same as the R/S and my dust shield is not concentric to the axle hub??? Any pixs would be helpful as there worth a thousand words.
Hi Guest!
