Wedge Rear Disc Brakes for TR7
Delmon
There was a post about installing rear disc brakes on a TR7. Can anybody point me in the right direction, because I cannot find it again.
tr8todd
There is no kit available that I know of. One could be made up without a ton of work. I recommend you start with a caliper that has a built in e brake attachment. I converted my BMW 2002 over to rear discs using a VW Golf caliper. Most people looking for rear discs on a 7/8 usually install a modified Ford 8.8 rear end, that way you get rear discs and a posi in a bullet proof package. The rear end Michael shows in the picture above is from his rally car reproduction. He had to have brackets custom made to locate the calipers, but I'm sure it can be reproduced.
WedgeWorks
The parts I have in my conversion are Ford Taurus SHO rear calipers with a spacial adaptor plate, spacer plate to replace the old rear drum mounting/backing plate, I think ford Tempo brake rotors mounted on a stock TR7/8 5 speed rear axle. It does not change the rim spacing but you cannot use the stocxk steel or alloy TR7/8 13-inch rims. You need to use an aftermarket 13-inch rim such as panasport, minilite, superlite, etc. I do not have an ebrake cable set up yet but someone will eventually.
Components to the conversion
tdskip
<span style="font-weight: bold">Way cool</span> - but short of racing does it make a difference on the street? Again - WAY COOL.
WedgeWorks
Oh it is a huge difference. You can dial the proportioning to the rear discs with a proportioning valve. Plus no more once every year or two years to worry about changing leaking wheel cylinders. You will have or can achieve a 50-50 braking and not a front nose dive with rears locking up and praying you make it!
Here are the calipers typical 1989-ish Taurus SHO with the small springs for the ebrake lever are even with the outside edge of the caliper. If the springs overhang then they will hit the rear coil spring of the suspension.
Below is the Works Rally raer calipers which are a 4-piston arrangment. They also use a hydralic master for the e-brake.
DNK
Mike on the top diagram there is a "angle 45 degree"
What gets angled?
DNK
Was leaning that way.
So that doesn't help with the e brake deal. Does a rally car need an e brake?
tr8todd
Modern rally cars actually use a second rear caliper for the ebrake. It is a hydraulic unit. When you pull up on the hand brake, the other end of the handle pushes against a slave cylinder that pushes fluid to the secondary caliper. It is much easier to modulate compared to a cable driven caliper. Now that's way cool!
DNK
Like this
Dave Richards Which Cars Had Rear Disc Brakes? Austin Healey 22
T TR6 tr6 rear disc brakes Triumph 30
milemarker60 TR6 My Rear Disc Brakes on the TR6/M3 Triumph 0
Gearhead Rear disc brakes on a Midget Spridgets 2
69MGC Rear Disc Brakes MG 11
G MGB rear disc brakes for an MGB MG 5
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
A AH 3000 rear disc brake conversion Austin Healey 28
Jim_Gruber Creative Spridgets Rear Disc Kit Spridgets 11
T 'Creative Spridgets' rear disc conversion Spridgets 6
steveg Rear Disc Conversion Austin Healey 29
S Rear Disc Brake Conversion Austin Healey 9
S rear disc brake conversions brackets Triumph 9
M BJ7 Rear Disc Brake Setup Austin Healey 7
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
Fortius Dennis Welch Rear Disc Brake Conversion Kit Austin Healey 2
R rear disc's MG 25
PAUL161 MGB MGB Rear Disc Brake Conversions MG 14
GregW Factory rear disc kits? Austin Healey 28
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
