General TR Rear Differential Seal
KVH
Can it be pulled while still in the car? Also, once the flange is pulled how do you yank the seal out of there?
M_Pied_Lourd
What car? And...what seal? Are you talking about the pinion seal?
Cheers
Tush
M_Pied_Lourd
I believe it should be the same process as on my TR3A then. I did it on the car and pulled the seal out with a seal puller tool (looks like a screw driver type handle with a hook on either side of it). If you are going to buy one, don't buy the cheapest you can find as you might find that it bends easily or the rivets pull out. After you get the old seal out, you can tap the new one in place using a seal driver or large socket on the outside metal part.
Cheers
Tush
titanic
+1-Specifically, don't buy the clone from HF. The hook bent on the first use. Lisle brand works and only costs about $10. Also, check the part of the flange that the seal contacts. If it is worn, try moving the seal slightly out of the worn area or use a speedi-sleeve.
Berry
sp53
Yes get a strong one because those things can be tight. Be cautious not to scare the outer edge of the housing were the seal seats by praying something between the two because it will leak between the seal and the case if it scares. It often takes some time to get the seal out because of the limited leverage from the tool, if it moves just a little work it out slow. The important thing is to put everything back proper; often that is putting things back just the way they came out, like counting the turns of the nut, you are basically resetting the bearing similar to a front wheel bearing , but with a 100 to 125 pounds of torque on the nut and a very slight drag on the bearing.
I put the new seal in with some kind of gasket shellac around the outside metal and a little grease on lips of the rubber seal
TR3driver
Great Pumpkin - R.I.P
I used a big screwdriver after the HF tool broke on the first pull.
I suggest setting the nut to the proper torque rather than trying to judge bearing drag. The correct drag is very light, hard to tell from seal drag. And it's probably best not to over tighten even if the bearings are a bit worn/loose.
Geo Hahn
I used the Harbor Freight seal puller 3 times successfully - the 2 TRs and a friend's Healey. But maybe I'm just lucky so yeah, get a better one if you can.
I retighten them by first marking the position of the nut before removal then counting the turns. Assembly returns them to the same position. This worked on all but the TR3 on which the nut was only finger tight (and presumably had been that way for the past 30+ years). In that case I went with torque.
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
T Rear/Differential "Clunk" Austin Healey 2
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
J TR6 Differential / Rear Axle Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
D TR2/3/3A rear shelf differential dome Triumph 9
C TR2/3/3A Rear differential Triumph 29
A Rear Differential Concern??? Triumph 11
T Spitfire Spitfire differential rear bushings Triumph 5
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
J Rear Axle/Differential Gear Oil Spridgets 13
zschicago Replace rear differential gasket? Austin Healey 12
R MGB MGB Tube Type rear differential MG 0
R use redline mt-90 in 1275 rear differential? Spridgets 3
N Differential and rear suspension Austin Healey 113
I rear axle to differential flange bolt grade? Triumph 8
N Rear Differential Rebuild Triumph 9
KVH Rear Differential Overflow Valve Triumph 3
Lin Rear Differential bearings Austin Healey 2
C TR2/3/3A Broken TR3 rear differential Triumph 9
G Rear Differential - Pinion Gear? Austin Healey 3
jerrybny Differential/Rear Axle Gaiter question Triumph 6
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
