I thought I'd check the damper fluid levels. Hmmm - both front dampers are dry. Filled with damper fluid, exercised them with a few body bounces, replaced filler cap, checked for leaks, no drips, keeping fingers crossed.
Per workshop manual, rear dampers must be removed from car to check fluid and top off. Fitting is similar to this:
Do I need to put the car on jack stands to remove the rear dampers? Or can I just remove the two bolts on each one and remove the units? I don't want to hear a loud "thwack"!
Thanks.
Tom M.
Thanks.
Tom M.
