bob hughes
Can the collective help me with this little problem on my BJ7?
The other day I experienced a problem after travelling in access of the speed limit of 70MPH on this side of the water - the engine started misfiring badly.
Checking the cylinder pressures (without oil) most cylinders were around 160psi +/- and number two was around 150psi. The plugs where white-ish. Thinking that I had burnt a valve I took the head off but all was OK there, changed the coil for another (not new) and checked over the points etc. Still no good. Changed the jet head on the front carb - due to a damaged rubber grommet - could not just by the grommet locally.
I took the car to my expert who changed the leads, end caps, points etc. and eventually had it running - with a strange note, not like the usual.
Brought it home and after 20miles into the journey - the misfiring started back again.
Took it around to me local garage and they kindly checked the exhaust gasses - the rear carb was running very very rich indeed, pulled the plugs and sure enough they were sooted up. Changed them for a new set and that temporarily solved the problem.
Tried to adjust the rear carb and now the jet head is up as tight as it will go and we are still running rich. The jet and the needle are both standard and the needle looks to be undamaged. On a whim, I have ordered up a new jet head for the rear carb and it should arrive tomorrow, but has anyone any other ideas as to why I can not control the carb? - Front carb is OK.
Hi Guest!
