TR4
Can you tell me where the return springs should be located on the rear brake shoes of a 64 TR4? The workshop manual shows both to be on the inside of the shoes. The PO has the adjuster spring on the outside of the shoe and the wheel cylinder spring on the inside of the shoe on my car. Could that cause them to hang up? I have had that problem and moving the spring to the inside would be the easiest fix I've run into on this car. I'm ready to let out a BIG WHOO HOO if that's the case.
